465.1 # enable vpex 465.1 # reboot Are you sure you want to reboot the switch? (y/N) Yes Slot-1 VPEX 465.1 #
After reboot, command prompt changes to show that you are in VPEX mode.Slot-1 VPEX 465.1 # enable vpex auto-configuration VPEX Auto-Configuration is enabled for non-MLAG configuration.
Slot-1 VPEX 465.1 # reboot
When the CB finishes rebooting, connected BPEs, extended slots, and LAGs on cascade ports are automatically configured.
Slot-1 VPEX 465.1 # configure vlan Default delete port all Slot-1 VPEX 465.2 # create vlan v100 tag 100 Slot-1 VPEX 465.3 # configure vlan v100 add port 130:1-2, 120:1-2, 1:7 tagged
Slot-1 VPEX 465.3 # show port 130:49-50, 120:49-50, 1:7 statistics no-refresh
Port   Link  Tx Pkt    Tx Byte    Rx Pkt    Rx Byte  Rx Pkt Rx Pkt  Tx Pkt Tx Pkt
       State  Count      Count     Count      Count   Bcast  Mcast   Bcast  Mcast
130:1  A   97045942 6209457963         0          0       0      0       0     35
130:2  R          0          0         0          0       0      0       0      0
120:1  A         36       4715  97001731 6206623104       0      0       0     35
120:2  A   95802538 6897726741  95784987 7279063658       0    512       0    697
1:7     A   97045942       4715  97001731 6206623104       0      0       0      0
          > in Port indicates Port Display Name truncated past 8 characters
          > in Count indicates value exceeds column width. Use 'wide' option or '0' to clear.
          Link State: A-Active, R-Ready, NP-Port Not Present, L-Loopback
Slot-1 VPEX 465.13 # show port 130:49-50, 120:49-50, 1:7 qosmonitor no-refresh
Port Qos Monitor
Port          QP1       QP2       QP3       QP4       QP5       QP6       QP7       QP8
              Pkt       Pkt       Pkt       Pkt       Pkt       Pkt       Pkt       Pkt
             Xmts      Xmts      Xmts      Xmts      Xmts      Xmts      Xmts      Xmts
130:49   119682459         0         0         0         0         0         0        45
130:50           0         0         0         0         0         0         0         0
120:49           0         0         0         0         0         0         0        45
120:50   119803233         0         0         0         0         0         0       923
1:7      119803233         0         0         0         0         0         0       923
